Basically you just hook the 12V lead of the tach to your battery somehow (an accessory port in the fuse box would be the cleanest way) and then interface the tach into the ignition system somehow, which is the EDIS4 module, which is located just in front of the front left strut tower. It´s the second wire from the left, should be green if I recall correctly. This basically is grounded every time the spark is fired, and then your tachometer takes these pulses as a function of time and can translate that into a voltage which in turn moves a needle on a gauge, at least that´s how I think it works. Hope that helps.
they are use electronic ign. Is there any place where you thing i might get more info on this?? websites, forums, message boreds?? Any help would be great
