installing a aftermarket tach? | Ford Escort Owners Association (FEOA)
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by Chad Gregoire, May 1, 2015.
  1. Chad Gregoire
    Chad Gregoire FEOA Member
    22
    I tried doing a search but didn't find much. I have a 1999 Escort SE Automatic and a tach would really come in handy for trying to sort out my transmission shifting issues. Thanks!
  2. Chad Gregoire
    22
    I tried looking on car-part.com to find a "instrument cluster" in Maine for my car, but can't seem to find any. Plus I have no idea if the one i'd go pick up would be the same as I have now with no tach...
  3. DrewsBrews
    DrewsBrews FEOA Donator
    326
    137
    103
    SW Ohio
    would need to know if it came from a manual trans car as I'm fairly certain they were the ones that came with tachs. Also the zx2 has a different cluster shape than the sedan/wagon.
    For an aftermarket gauge you would look at the instructions for the gauge as to how to install. Likely tap off of, or wrap a wire around, one of the spark plug wires, then run it through one of the firewall grommets and up to the tach. It may also need a power/ground which isn't too difficult to find.. tap a fuse for power and use a bolt tied to the body/frame for ground.
  4. 22732
    22732 Guest
    manual or auto transmission had no bearing on whether the car came with a tach cluster or not. It was just an option that was available on the higher packaged escorts. (Escort LX and Tracer LS) Mines an auto and came with the tach cluster. You can find a tach cluster in a junkyard and it will be plug and play.
    copcarguy likes this.
  5. copcarguy
    copcarguy FEOA Member
    1,978
    840
    263
    Northeast PA
    You car is pre wired for a tach, as said above it's as easy as finding a tach cluster and plugging it in.
  6. pcordes1979
    pcordes1979 FEOA Member
    348
    52
    278
    Aurora, IL
    When replacing the cluster, don't even worry about trying to find a car with a mileage close to yours.
    Once you acquire the tachometer cluster, simply move the speedometer module between the two clusters, as it is the same for both the tach and non-tach clusters. Simple as that, takes a matter of a few minutes to do, just need the right sized torx driver (T-15 sounds right but will have to double check). Pull the bezel off, pull the speedometer module out install the one from the stock cluster and put the bezel back on.
    Dan GSR likes this.
  7. MenaceMan47
    MenaceMan47 FEOA Member
    248
    62
    178
    New Mexico
    PCordes is right; I did the same thing to my 99 SE 5-speed last year with a cluster out of a 99 LX. You can swap speedos between the two cluster units pretty easily. The red circles indicate the pin-out arrangements, and they are all the same between different 3rd-gen Escorts (non-zx2 models)
    Use a small flathead screwdriver to gently pry the speedo unit out of both tach clusters and just swap them. Make sure the prongs are lined up in the holes before you insert your speedo into the cluster you got from a junkyard/ebay/wherever.
    It's really as simple as that.
    Dan GSR, DC Ultra and copcarguy like this.
  8. DC Ultra
    DC Ultra FEOA Donator
    414
    68
    178
    so does the other background material enforce the legitimacy of the mileage?
    hah. :roflmao:
  9. MenaceMan47
    248
    62
    178
    New Mexico
    Not sure what you mean... the donor tach cluster came from a vehicle with 80K miles on it, about half of what my vehicle currently has as of today.
  10. pcordes1979
    348
    52
    278
    Aurora, IL
    I think he is referring to your reloading/handloading setup that is in the background of your pictures. Meaning, he is asking are you using "force" to say that the shown mileage is the actual mileage. Jokingly of course, I think...
  11. MenaceMan47
    248
    62
    178
    New Mexico
    It's the actual mileage of the donor vehicle only; I still have that speedo with my original cluster, but not installed in my vehicle.
  12. DC Ultra
    414
    68
    178
    i just found it mildly amusing that you have pics - good ones - of the cluster change on a firearms safety mat and some bullets in the background.
  13. MenaceMan47
    248
    62
    178
    New Mexico
    What can I say? My workbench sees alot of action, be it automotive or firearm :)
  14. LariRudi
    LariRudi FEOA Donator
    2,341
    219
    313
    I know you're saying that for Gen 3 it's basically "plug and play".... but did I see someplace in these forums that the 1997 is NOT plug and play? requiring moving wires and pins around?
    Just wondering....
    LarryR
  15. DC Ultra
    414
    68
    178
    umm... i thought they are plugnplay for the third gens? where did you read otherwise?
