Hi everyone!
Add: I currently drive a 2000 Ford Escort ZX2, forgot to mention that in my post.
I've got a bit of an issue with my car after I recently installed an amp. I bought a (i believe) 8 gauge wire that I ran from the + terminal on my battery to my trunk, where I threw my amp.
(for those curious, the amp I purchased is this: http://www.crutchfield.com/p_575R3004/R ... tml?tp=115)
I also installed a set of new speakers as well, so the only stock thing in the car when it comes to audio is the HU, which I'm not using.
Now, yesterday I mounted the grounding wire to an exposed metal surface on the side of my trunk, and then wired up the + wire coming from the battery. I had asked one of my friends about where to hook the "remote control" wire, and I ran it to a 12V lead that went to my stock HU. As far as the stock HU goes, I unplugged it, and am currently just running a headphone-to-RCA wire from a MP3 player in my car to the back as a temporary solution.
Now here's where the problems come in. I noticed my car started just fine, the amp worked perfectly. No audio quality issues from what I could tell. So I drove down the road, and parked, and saw that my dome light would not turn on. I figured that it was acting funny and it'd "just fix itself". So much for that... Then today I drive to school, go to lock my car with the key fob. No luck.
As I drive home I then noticed another issue with my car. Normally I can sustain ~2.1k RPM on my tach, but I had an odd issue as I was driving: my car would drop down to about ~1.2k, then speed back up like normal.
So i get home, and pull the amp fuse, and I still had the dome light issue and the keyfob issue, so I check the fuses and the Room fuse is blown.
Does anyone have any insight as to what I should do from here? Or if there's something I really screwed up with? I double-checked my connections, and I'm not tooo car-savvy (I'm more of a computer geek).
Any help would be greatly appreciated, and I apologize in advance if this message seems a bit jumbled, heh.
Thanks!
(For those wondering about my interestingly wired configuration with my mp3 player: I plan on installing a computer in my car)
Thanks!
