Inner tie rods | Ford Escort Owners Association (FEOA)
Inner tie rods
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by Gabriel Panoussi, Dec 21, 2016.
  1. Gabriel Panoussi
    Gabriel Panoussi My approval ratings have droped.
    162
    34
    88
    Flint, MI
    So it has started to snow here and I am all over the road. I know one o my issues is that I need an allignment because I did swap out the old tie rod ends. However, when I did the tie rod ends I also noticed that my inner tie rods were bad. When I picked them up they just fell down with no resistance. I never did do an alignment after changing those tie rods.
    Now I have ordered the parts for the inner tie rod replacement in an effort to solve my issues driving on snow and bad outer tire wear on rear tires.
    My question is this, when I ordered the replacement tie rods there is a small locking allen wrench screw near the part that screws onto the rack. I can't know for certain that mine has been replaced or is OEM but generally speaking when I uninstall the tie rods will there be an allen wrench nut I will have to deal with on the old one? The car is old and rusted the thought of having to remove a tiny allen screw at the pinion makes me not want to do this job.
    I know I will need a loan a tool to remove the ends and the inner tie rods. I Do have a bore scope but to get a view I think the boot would have to already be off. At that point I would be committed. Thanks or the replies and happy holidays!
  2. bent_rod
    bent_rod FEOA Donator
    1,566
    232
    213
    Kansas City
    The OEM inner tie rod end on my 2000 SE had NO allen screw.
  3. Pizzaman5000
    Pizzaman5000 FEOA Donator
    1,504
    233
    Central OH
    Mine is ten years older, but it had no Allen, and the cheapest tie rod tool from AutoZone worked great for me (along with several extensions). Now is a GREAT time to do the passenger side inner sway bar bushing.
  4. DangerRanger
    DangerRanger FEOA Member
    230
    29
    178
    Howell, Michigan
    I changed them out on a sedan that looks just like yours. I do not believe there was a set screw on the originals but do remember there being some on the replacement. I made a custom wrench like a suuuuper deep socket that you put down over the top of the whole inner rod. I believe you can rent them, I made my own. ( I make tools for everything ) I dont remember if I reached way in there and tightened up the set screw. I think I just put a lot of lock-tite on it and called it a day. Mine were getting to where they had some serious play and klunky
