1 - 12 of 12 Posts
Hey Team!
I recently purchased a 92 Escort GT! I'm super excited to be working on this platform again. I have a "big kid" job now and can actually afford to build a car.
Although, I am kicking myself everyday for not keeping all the junkyard parts I scored for the wagon back in the day!
The chassis is apparently from Oregon and has a little bit of surface rust but none of the rot I am used to seeing here in the Midwest. The motor is reasonably low mileage that came out of another GT that fell victim to that Midwest rot.
I am going to do my best to get rid of the little bit of rust that is on this car, and get the body back into shape.
Once I have the rust prevention in place I plan on boosting. Nothing too extreme, but I want to hit the ~250 hp range hopefully.
I'm going to be changing the brake pads before I take this to Missouri in October. Any suggestions on brake pads? I did a quick search but didn't find anything.
Hopefully I will also be able to swap to the V6 Probe clutch that came with it before then too.
That's all for now, time for some pictures!
Love the black piping. I was thinking MX-3 swap until I saw these, but It might be hard to let these go.
These fanblades were originally Caymen Green! If I'm lucky there might still be a trace of them under there.
It was about a 7 hour round trip in the U-Haul truck. You don't realize how much a proper stereo matters until you don't have one.
Looks like a monster truck next to my Civic!
Please do your Plastidip right!
After a lot of Goo Gone and some time. Does not want to come off of the rubber trim.
After starting some cleanup I decided to bathe her as well.
Thanks for taking a look, more to follow!
Sounds about right Joey! I found some Ceramic Carbon fiber blend pads, holy cow! Think I'm just going to go with some regular ceramics.
Did the valve cover gasket and new plugs & wires last night. NGK wires and NGK BKR6EGP plugs set to .030.
Thought the wire routing looked okay, but is there a "right" way to do it?
Also got new headlamps put in with some clear corners!
I need to get my hands on a shop manual. I can't find my old Haynes. As little help as it was, it's still something.
Major score today! Gotta love having yards that track their inventory.
86 RX-7. Looked like it was a track car at some point, dash was stripped and replaced with a steel plate with switch holes, wiring was a mess!
I read an adapter for the filter was necessary but DANG!
Don't know if I'll use the K&N, I've read the oil is bad news for the engine. Gonna do some more research cause this looks like a decent setup.
I don't know why the oil would be bad for the engine. There is always a small amount of oil getting sucked into the engine through the PCV system. After a few miles any excess oil on the K&N filter should be sucked off so no more will be released anyhow.
Discussion Starter · #8 ·
Joey, you're definitely right. I did some research and I found the thread that made me think negatively on K&N and it was actually saying they let a bunch of dirt through and some people way over oil the filters. There was no real definitive info either way, but after reading up I don't have any issues using the K&N after a proper cleaning.
Although I did also find out about Amsoil EaAU filters which I might upgrade to in the future: http://www.amsoil.com/products/ea_filters/EaAU_Photos_and_Specs.pdf
Dang, I was just in Louisville last weekend! I'll have to swing that way again soon, is not a bad drive at all.
Just so you know. They will be putting tolls on the new i65 bridges across the Ohio river soon tho.
"Gotta love having yards that track their inventory."
Yes, that would be a great thing. About a month ago I drove to a junkyard 500 miles away to pick up a 1990 HO engine which turned out to be a plain old 91-96 SEFI.
The yard did however have a HO or GT 1.9 head which I bought for half of what they originally had it listed. They then dug up the exhaust manifold for it, which turned out to be a Toyota cast iron lump that someone wrote 1990 Escort 1.9 on.
But I also visited a relative on my trip and was keen on a bit of a road trip adventure so I was still happy to have gone.
The drive was mostly on two lane highways through southern B.C., so pretty similar to northern Montana and Idaho, wonderful country.
1 - 12 of 12 Posts
