1 - 6 of 6 Posts
I was putting on my winter tires…. and well I stripped 2 studs … in the rear driver side wheel.. and … messed up two mag locks…… The hub I had replace not to long ago..(Wheel bearing) My understanding is that you can press these out and buy new studs ? has any one done this or attempted this at all ?
Anyhow its looks like this... X is the mag locks that are on and O' is the stripped ones :D maybe I'll get lucky and the wheel will fly off :D
X X
O O
I've not done it on an Escort... but I've done it on other cars. Fairly simple process: Remove the brake drum (or rotor), push out the old (bad) stud, and press in a new one.
I work at a Sears AutoCenter and we do this stuff all the time.
Just take the assembly (wheel bearing) or drum or whatever off...
just take a good sized hammer and a screw driver or whatever and pound out the remainder of the studs. Put new ones in and tap them in securely then re-assemble.
BYO Plastic cutlery
they are supposed to be pressed out and in with a big hydraulic press. Hammering them out is fine but I don't know if you could press the new ones in far enough that way. Not saying you can't, just not sure.
Did them all with out talking the hub off :D once you tap the old one out……….. you just…. Push them in and flip the nut around (so its backwards). Once you tighen it enough its press it in… in doing this I snap One of the new studs apparently .. I was a lil too tight :D …. So now its
X X
X O
I'll have To pick another one up tomorrow :D
1 - 6 of 6 Posts
