excessive resistance (bad plug wires), or a bad coil. if you have a multimeter you can measure the plug wires. iirc they are supposed to be less than 10k ohms per foot.
i`ve try 4 coil and it all do the same , at the coil wire and at the coil itself, its just a little spark. What part make the coil spark i think its a sensor in the distributor
Blaster 2 (MSD Coil), MSD 6A (MSD stands for Multiple Spark Distribution) Its an ignition kit that when your computer sends the signal to your coil to produce a spark, instead of one little spark the MSD ignition system produces mulitiple amplified (much larger) sparks per cylinder.
Heres the system on my car. Took it off my mustang. works perfect.[/img]
yep i know that kit or put a msd blaster 2 but im going to put the bp in other car and i dont want to put a lot of money in the scort . I only want to start the engine after doing the swap
