FordMan59 said:
Take a look at the tires. If they're any signs of dry rot or cracking then you might want to replace them, but I am still driving on the original tires on my '97 wagon and it only has about 26K miles, but it is garage kept and the tires are not exposed to the weather and sunlight. I'd take a look at the belts and hoses and if there was any question about the condition I'd change them, otherwise I'd leave them alone. If I didn't know when it was last serviced 'd go ahead and do an oil change. I'd also give all the brakes a good going over and replace any worn or damaged parts. The old lady probably just drove short trips so she probably used the brakes alot maybe wearing out the pads and/or shoes.
The oil change is fresh pretty much, 1200 miles and it needs done..but I'm going to do my own oil change because I don't trust dealerships and there shenanigans.
I have to get the car inspected so when they do that I will see if anything needs replacing. I will also ask my brother who is an auto mechanic to check everything...He's bust right now though working on his VW Golf, he's putting in a new clutch and and tranny.
Thanks for everyones advice...So far I have:
Belts - Check/replace as needed
Brake system- Fully check/replace as needed
Tires- Check for rotting and other wear, replace if needed
Anyone else got anything?? I might get it today ;O!
