1 - 2 of 2 Posts
Hi I'm new to the forum. I have a 92 1.9L wagon and my thottle sticks. I'll rev up to 3000 rpm or what ever and when I put the clutch in the rpms stay reving up there. Then I'll turn it off wait for 3 seconds, turn it back on and it will stop for a while. I tried cleaning the throttle body with some B-12 carb cleaner and it seems to help for the first 50 miles then its rev city again. What gives? I have new air oil and fuel filter new plugs, wires, pcv valve. Help. :?
Have you checked for vacuum leaks and air leaks?
I'd probably remove the IAC and clean it out real good, maybe even soak it overnight in something (soak the mechanical part, not the electrical part). On the older ones (like from my 1994 GT) you could take them apart like that. Not sure if you can do that on these newer ones though.
1 - 2 of 2 Posts
