I have 99 se 2.0 L. Ever since I got the car (3 years). It has always had a rough idle. I had 2/3 motor mounts changed, one of the transmission mounts included. After that it got a little better. I changed 2 of the breather hoses, the one that comes off of the valve cover and the one under the throttle body. I changed the pcv valve as well. I also changed the spark plugs, plug wires, and ignition coil.
So when the temp on the car warms up and I’m sitting at a light, the rpm’s start to go up and down between 500 and 1000 and eventually stays at like 900. So basically I don’t know if it’s running too lean or vice versa. Anyone have the same issue? Any advice or help is greatly appreciated
