1 - 5 of 5 Posts
i have a 93 wagon 1.9 litre automatic with a/c.
sometimes the idle will plummet down even to the point of stalling . it can do this with the engine warm or cold. another problem, which may not be related, is that there is a bit of stumbling going on at speeds over 55 mph (90kph). nothing serious, but it's noticeable
new plugs, fuel filter and air filter didn't cure it, and a visual check of the plug wires shows no damage.
can't find any obvious vacuum leak ... there is a mild hissing in the intake area but i don't know whether that is a small leak or normal intake sound.
anybody had this problem ?
could be a vacuum leak, could be a bad throttle position sensor (TPS)
Look where the PCV elbow meets the intake mani. Check for cracks, especially on the back side of the elbow. That is a known problem, one that I experienced multiple times.
thanks very much for the input, dave and pextor. didnt have time to do anything today but will follow up on your suggestions tomorrow for sure.
thanks again.
How many miles are on the car?
I replaced my IAC at 150,000 miles, and wish I had replaced it earlier.
I also suspect vacuum leaks. get a Mityvac and learn hot to use it.
1 - 5 of 5 Posts
