Idiot p.o put 90w oil in trans | Ford Escort Owners Association (FEOA)
Discussion in 'Drivetrains' started by garyd, Mar 18, 2020.
  1. garyd
    garyd FEOA Member
    406
    23
    278
    It's a 93 1.9 5 speed.
    Would this cause any damage to trans
  2. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,508
    1,170
    Vancouver Island, Canada
    Unlikely. Just drain it and replace with ATF.
    I had to add fluid to my car on a road trip last summer, and the parts store listing specified gear oil.
    However, I knew it should be ATF and bought that instead.
    Many years ago I checked the transmission in a new to me 1963 Valiant and found ATF in it. I also thought some knucklehead screwed up, but it turned out that ATF was the correct lube in that three speed, non-synchro first gear transmission.
    I took it apart later just because that is what I did with everything I had when I was young, and found it was made pretty much exactly like all the other three speeds that used gear oil.
    So I conclude that transmissions are pretty forgiving about what lube is in them.
    Pizzaman5000 likes this.
  3. garyd
    garyd FEOA Member
    406
    23
    278
    Ok good.
    I was worried.
    I did drain it.
    Drain plug was really tight but it came out with a breakerbar
  4. garyd
    garyd FEOA Member
    406
    23
    278
    Got my new speed sensor. I found if you sand the part that slides in the case down a bit and put antisieze on it the come right out
    denisond3 and zzyzzx like this.
  5. zzyzzx
    15,189
    1,225
    Let us know if it works any different.
  6. garyd
    garyd FEOA Member
    406
    23
    278
    Trans seems to work good but now the power steering pump is bad
  7. xCroix
    xCroix "I used to have one of those!"
    17
    I know it's not an escort, but my '88 Camry uses Dexron III in it's 5spd trans.
  8. Joey_Twowagons
    2,508
    1,170
    Do you need a spare?
    There's one near me, cheap:
    $40 · 1987 Toyota Camry 5 speed transmission
    Report Ad
    [​IMG]
    • [​IMG]
    • [​IMG]
  9. xCroix
    17
    That's a good deal! But it's already been swapped with an '86 Celica transmission (also Dexron III) that's doing fairly well
  10. marclar
    9,040
    599
    seabeck WA
    there are are a hundred thoughts on this topic... the atf flows better and doesn't go acidic as easily as gear oil in this application..
  11. Joey_Twowagons
    2,508
    1,170
    The ATF will have less drag on the moving parts, so will give minutely better mileage, which might be of interest to the manufacturer.
  12. novanutcase
    novanutcase FEOA Member
    2,570
    615
    263
    I always use Mercon in my Ford Trannys. Haven't had a problem yet.
    John
  13. Joey_Twowagons
    2,508
    1,170
    I figure since I ran my transmission dry, filling it up with anything close to the designated fluid will make it a hundred times better.
    Happily my transmission has been fine after last summer's debacle when I ran it out of fluid to the point of it popping out of gear when driving.
    A couple years ago it started to pump its lube out the speedometer head, so I was in no hurry to top it up.
