1 - 15 of 15 Posts
What can i do to my 1.9 L motor to get 200 plus horses with out using turbo or nos.......can i please get some help
errr... have a 200hp car tow your Escort, that's about the easyest to do it with out boost or N20.
Lot's of N/A all motor power is very exspensive, that why you dont see any 200hp all motor 1.9's. It's possible but gonna cost thousands.
I suggest a swap of some kind.
out of that engine? its very very doable. not hard at all.
trick is to sign alot of checks with 3-4 digits to the left of the decimal point.
14:1 compression, 120 octane race fuel only, about $1000 in head work, custom ordered rods and pistons to handle the power, a balanced and forged crankshaft, might need to sleeve the block, custom manufactured axles to hold up to the torque, a reinforced manual transmission with a traction-lock differential, custom made intake manifold, a re-programmed ECM, about 32-42# injectors with a larger fuel rail and fuel pump...
need i go on? i know how to do it, can you fund it?
I bet it could be done with just the 14:1 pistons, custom intake manifold, huge throttle body, huge valves, cam, ported head, and header, custom chip, for lot's of timing, big injectors, and the use of high octane gas, and a strong clutch.
The stock rod's, tranny and axles should beable to take 200hp.
But that's a lot of machince time and custom parts, not cheap...thousands of dollars....or you could just slap on a $300 N20 system and hit 200hp by the end of tomarrow. (with supporting management)
So jeff? Seeing what all i have done whats your guess for mine? I've had a few ppl tell me around 170 or so. Hell they have even started a pool up at work lol.
thats true jeff, stock short blockis good for 220ish hp.. i was thinking more than that wheni was typing away.. i was actually thinking about 300hp with nitrous.
im happy with my 1.9, 9.3:1CR and all that other crap you know i have that im not going to post again for respect of webspace..
I put a viper v10 engine, 32" rims, low profiles, eibach 21" drop springs, twin t66 ball bearing turbos, a 1200 shot nitrous system, 6 audiobahn subs, and a headrest dvd player on my push mower. Seems to work well.
(Don't believe anything I say, but that would be the shiznit, wouldn't it?)
8O I know that lawnmower.......................
(Don't believe anything I say either! :lol:
1 - 15 of 15 Posts
