Engine - I put a 351w V8 into a 99 Wagon | Page 2 | Ford Escort Owners Association (FEOA)
Engine I put a 351w V8 into a 99 Wagon
Discussion in 'Engine Swaps' started by BigBad, Feb 1, 2020.
  1. BigBad
    BigBad FEOA Member
    21
    6
    165
    Photos are pretub and possibly miss leading. The coil overs are not notched and don't come in contact with the rear tires. Possibly the shadow of the cut out from the body work makes it look like they are resting on the tires. The tubs come in to right to the coil overs but not past them. Let me see if I can pull up a different angle. 20191130_170012.jpg 20200107_220149.jpg The tub lips inward just over the top of the coil overs. The tubs have close to 3" of clearance around them for tire deflection from the suspension and tire movement or growth. The first photo shows where they connect at the top. The second is not a great photo, but shows placement of the base of the coil over to the tire. I just posting off what I have in my phone.
    I'm not sure if that answers your question or if you were seeing something else. I'm always open to double triple checking my work. It would not be the first time that I thought a design would work great, then say to myself after it's built, what on earth was I thinking? Lol
  2. ndlm8888
    ndlm8888 scortin daily
    983
    341
    213
    tampa bay ,fl
    Wow this is insane. Top notch Fab work. Would love to see this in person. Would be awesome to barra swap.
    BigBad likes this.
  3. marclar
    8,833
    497
    383
    seabeck WA
    amazing work. one day i will get mine started... hopefully .
    BigBad likes this.
  4. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,243
    1,006
    Vancouver Island, Canada
    Yes, a 351 in an Escort.... what on earth was I thinking?
    But it's great to read about it!
    BigBad likes this.
  5. BigBad
    BigBad FEOA Member
    21
    6
    165
    Barra would be killer. Would probably have to do a serious set back to make it work. At that point you could make the whole car flip up like a funny car.
    The plan is to attend an up coming Hot Rod Power Tour and the Drag Week. I built in a trailer hitch for pulling a small trailer. Once I have it running reliably, I'll sign up, and post where I'm going to be.
  6. BigBad
    BigBad FEOA Member
    21
    6
    165
    Right!?!!
  7. BigBad
    BigBad FEOA Member
    21
    6
    165
    It's been a bit since I have had time to work on the Escorch. I have some family stuff going on. And I needed to move build operation location. 20200208_171246.jpg
  8. BigBad
    BigBad FEOA Member
    21
    6
    165
    The struts I used to originally setup the front suspension were shot, and were 2004 sn95 mustang type. The escort hood line is lower than a mustang. I can back off the coil over adjustment for the springs, but then the range might not work well with the travel and bottom out going over a bump. At full extension it might also be possible to have the spring un seat. Sooooooo.
    Had to come up with a viable replacement. Since the front end is mustang, one trick is to mate the older style Fox body struts in place of the sn95 ones. This shortens full extension a good inch and more than that under compression. I bought the Strange 6001em Fox body struts. They have a really basic rebound adjustment so they are not a full race type strut, but more importantly, they are not full race priced. 20200208_155417.jpg 20200208_155445.jpg 20200208_173917.jpg 20200208_191433.jpg
