i need help and i hoppe some one can help me do not know wha | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by greg91gt, Jun 6, 2010.
  1. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    think you so what do you think about it i know it is not the bast but she is mine if you know what i mean
  2. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    I understand fully, it is a fun car and great to learn with. It is a work in progress as mine was once. It have potential; drive smart, don't beat on the trans, and it will give back as much as you put in. Mine was originally a '91 GT as well and it has many original parts still doing fine and pushing 200K. Start narrowing down the issue and you will find the cause.
  3. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    i have a mitsubishi distributor, and
    So the engine dies when giving throttle yas
    not staying running at all?and that to yas
    Change anything prior to parking it? no
  4. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    Mitzu? Do you mean Mazda? I would check the intake items to start. Since it seems to fire and run briefly, other systems would seem OK. The VAF might be bad, sticky, not properly plugged in, corroded connections. Your issue is probably a small one, which can be hard to find. If you were a local, I'd run my spare VAF over to eliminate it as a suspect.
  5. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    no i mean mitsubishi distributor, and i have mitsubishi fuel systume
  6. juggalo
    juggalo New Member
    6,096
    9
    Tacoma, WA
    that might be why ur engine don't wanna start.
  7. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    Off what Mitzu? Because Mitzu makes many electrical parts for many cars, the alternator is a mitsubishi.
  8. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    im not shere what car and the alternator it stock i think
  9. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    I believe all the EGTs have the "Mitsubishi" alternator, I know mine does. I assume the car ran with that distributor before timing issue and storage?
  10. juggalo
    juggalo New Member
    6,096
    9
    Tacoma, WA
    good point cuz my crx has a mitzu alternator.
  11. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    ya it did but it had a bad idle i mean bad you had to give it a gas to ceep it frum dieing but when the motor got really worme then it will idle
    i know i did not spell it right so if you can not read it then just ask me to re right it
  12. juggalo
    juggalo New Member
    6,096
    9
    Tacoma, WA
    idk if the 1.8's have an idle air control valve but that's what chilton(repair manual) is showin me and that sounds to be the culprit. if no IACV then IDK
  13. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    im going to look in to it tommorrow
  14. FordMan59
    FordMan59 FEOA Member
    4,500
    401
    333
    Russellville, Kentucky
    Have you tested your coil, plugs and plug wires?
  15. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    ya and i just got new msd coil, plugs and plug wires
  16. racethisescort89
    racethisescort89 New Member
    2,391
    In your closet watching you secks!
    sounds to me like a possible fuel starvation. although i haven't read the entire post from front to back. but if you have to keep in the throttle to keep it running here are some more options.
    A.Leak in intake system
    B.fuel starvation
    C.air fuel mixture screw turned in to far
    D.Throttle position sensor turned wrong
    That's all my little brain can think of right this minute.
  17. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    i will look it to that
    i got the car to runn and it will idle know but still boges down and still have new power
