i need help and i hoppe some one can help me do not know wha | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by greg91gt, Jun 6, 2010.
  1. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    ok aver time i start it i a rabse up and then dies or it will start tthin just die and whin i give it gas it dogse down and whin i drive it the motor rabe up evin if i do not give it gas plz help if you think you know evin if you dont im willing to triy anythink
  2. treeps95gt
    treeps95gt New Member
    796
    st.catharines, ontario
    try using the spell check so we can understand what your saying
  3. nezwick
    nezwick FEOA Member
    3,149
    4
    288
    Pennsylvania
    Lol this guy made the same post in the 3rd gen section. I asked if he failed Elementary school.
  4. Bomdoutscort
    Bomdoutscort FEOA Member
    1,249
    10
    288
    Cincinnati, Ohio
    Sounds like the air flow meter isn't plugged in all the way of a big vaccum leak
  5. Dave94LX
    Dave94LX FEOA Donator
    5,787
    238
    Under the Stairs
    cut him some slack guys. He needs help to get his car running.
  6. nezwick
    nezwick FEOA Member
    3,149
    4
    288
    Pennsylvania
    Alright. Well we can at least start by finding out what car he actually has. This was posted both in the 2nd gen GT and 3rd gen sections.
  7. Dave94LX
    5,787
    238
    Under the Stairs
    if I remember correctly, he has a 91 EGT. I will move his other thread into this section as well. I talked to Greg on myspace, and told him that he would most likely be able to get the info that he needs here. It's been almost 10 years since I have owned a BP, so I was hoping someone here could help more than I could
  8. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    sorry i can not spell all that good i know this is not how you spell it but im dislasick. but i have a 1991 ford escort 16v i think it is a 1.8 but im not shere and im new here and i f up and bup my post in the roing plase and that is my bad sorry but ya ok it was a street racing car timeing baelt broke retimed it be for i timed it it sat upp for about 7 to 9 months and befor the timeing bealt brock it would not idle right and know when i start it it idle up then dies or when i start it it will bog down and when i give it gas it die
    tell me if you can read that is not im sorry i will try to spell batter[/img]
  9. FordMan59
    FordMan59 FEOA Member
    4,552
    442
    333
    Russellville, Kentucky
    Have you rechecked to make sure the timing is set right?
  10. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    i had 2 ppl look at it and they sad it was right but we timed it to stock and i was told it was not stock the motor had work done to it would that make a differents
  11. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    Sounds like an intake air or vacuum leak as stated before. If it sat so long, it possible the fuel is bad, filter clogged/restricted? I bet the rubber intake hose has developed a crack. Inspect it for any possible air leaks. While it was sitting, a rodent might have made home of the air box. I have seen clogged air filters and damage to other cars from pests. Is it possible the VAF has an issue? Take the VAF off the air box so you can move the flapper/vane while attempting to run. It must be properly connected to the intact intake tubing...
  12. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    i have a k&n on it all new i droped the tank and clened it out and new gas filters but i will chak it all agin and i will get pic of it and i will try to put thim upp so you all can see what im working with if that will help
  13. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    A cone filter eliminates an air box issue. Though removing the cone an messing with the vane door to see how it responds couldn't hurt. Pics would be nice, are you running a stock intake rubber tube? They tend to develop cracks and leaks which the system does not like. I am just saying where I would start from the description provided. Maybe a faulty/sticky TPS or IAC?
  14. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    im trying to get a pic upp now and im running a matel tube do you know how to get the pic on and it is a older pic of it but it is all the same still
  15. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    You must host the image on another site; myspace, facebook, photobucket, etc. Then copy the URL address/img code and paste in your post.
  16. greg91gt
    greg91gt New Member
    17
    louisiana downsvill
    ok i will try that think you url]http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=101294929&albumID=2336093&imageID=38273300[/url]
  17. juggalo
    juggalo New Member
    6,096
    11
    Tacoma, WA
    what u need to do to post pics is to right click on the photo, copy the image url, type in [​IMG] and u get this
    [​IMG]
  18. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    Close...
    [​IMG]
    [​IMG]
    [​IMG]
    I will put up your other pics if you want, but try practicing in the testing forum.
    Looks like a newer distributor, a good reman? So the engine dies when giving throttle or not staying running at all? Change anything prior to parking it?
  19. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    HAHA, thanks Juggalo! You beat me because I posted 3 useful pics. :lmao:
    Just messing bud, we both work to help!
  20. juggalo
    juggalo New Member
    6,096
    11
    Tacoma, WA
