1 - 7 of 7 Posts
This was the donor that fed 3 different cars.....All the other parts are in the back yard under tarps...The race car should be painted real soon...you can see it in the garage in the 4th photo
Grav1ty
Wow. That's a very thoroughly picked GT.
My sister's 91 EGT died last winter and due to the consequences I only had 1 hour to run downstate and pull of parts. You wouldn't believe how much stuff I got off of it. But then again, I was also pissed off about what I had to leave behind (perfectly good rear axle/discs, wheels (the car had to be roll-able))
Either way... looks like you had a lot of fun! Did you use a plasma cutter to get the frame in half?
18 Volt Dewalt sawzall.... Cuts them up real nice....I will cut it up a little more so I can use the pickup ti take it away...
Grav1ty
Even the roof sheet metal will be used for other projects....
1 - 7 of 7 Posts
