TURBO!
I however, don't know what to do with it. It's a Warner-Ishi IHI turbo, "freshly" rebuilt, no shaft play and is in pretty solid shape I think.
Before I even consider putting it near the escort, I plan on pulling the motor, then going from there. I want to use this as a learning process, and a good point for my first 'fast car' build. I don't know much about actually working on cars, as I've never had to. Just short of a battery here, alternator there, or redoing the drum brakes; I've never dived into the internals of a motor. Here's a good chance I suppose.
I'm using this for some information as well; I've read, and re-read the Escort performance thread a hundred times and still haven't figured out where to start yet. I have been talking to a SVO mustang guy, and he's been aiming me in the right direction. Naturally I'll need new injectors, fuel pump, turbo manifold, and all the hard parts; and I've read the stock internals are allegedly good up to about 8psi, but is that accurate? Should I look at replacing things while I've got the motor torn apart? Since it does have a slight leak now, I was going to replace ALL of the gaskets while the motor is out of it, but should I look into a rebuild as well?
Nothing big will be happening with it soon, I was going to use it for a summer project, but I'd like to know where I should be starting. Any input?
