Be honest, but is this thing drivable (update: probably not, at least not very fast)? I just picked it up for 1k and I have a feeling I'm toast. That's the rear left mount. you can see daylight. Didn't see it when I looked at it.
It looks like some people have swapped in donor towers from other Ford escorts. Can I grab towers from any old escort or does it have to be a wagon like mine (update: you need a wagon strut, the sedan strut appears to tie into the trunk and all that, so it won't fit...)? I’m tempted to keep it alive (I mean what are my other options really besides junk it). It has 90k miles, fresh fluids, fresh plugs wires, valve cover gasket (probably needs timing belt, wheel bearings, brake pads, oil pan gasket; eventually catalytic converter). Runs pretty good but I’m wondering if this is terminal? I’ve seen some repairs of these on here (probably not as many as you guys), but what do you all think? I have no experience welding, but I guess my 1000 dollar car is the time to learn??
Those are my strut towers. They are rotten. I THINK the front side might not be as bad as the rear pictured here (update: is is on both, but the middle part of the right one appears to be more solid). I made the holes with my fingers just checking if it was rotten (I know, the paint was probably structural). Front towers aren't bad. Just the rear ones luckily (if luckily is the correct phrasing).
Looks like fuel filler neck needs replacement as well...
