1 - 1 of 1 Posts
Administrator
the oil feed for the turbo comes from the oil pressure sender in the rear of the motor. its a pretty good idea to use a oil cooler before the turbo. for example; my oil feed goes:
sender-> oil cooler -> valve -> pressure guage -> turbo
using a pressure guage and a valve is a good idea to insure the proper turbo oil feed pressure.
the oil drain should be drilled into the oil pan as high as possible.
i used a 1/2'' barbed fitting. i put it in the pan and jb-welded it on the inside and outside.
1 - 1 of 1 Posts
