how to smoke a mustang for 0$ in 7 steps.
1. remove a/c, spair tire
2. cut as much useless steel away as possible (stay safe)
3. remove air intake silencer (aka the trash celection box below filter)
3.5 cut hole in steel where the silencer was,cut toward front of car (allows cooler air to new intake entrenace).
4. (optional) remove stereo, speakers, door panels.
5. (optional) disassemble seats and remove as much steel as possible and take the sliding unit out and weld your own brackets.
6. (usually overlooked) if you replace it cost around $30, but if you remove its free) replace trunk with a home made fiberglass one that is held down with hood pins, or for the free way (kinda a pain) un bolt the 4 10mm bolts (iv figured just leave it at the start line.
7. cut about 2" of your exhaust behind (toward the engine) the muffler and leave you muffler sepperated from the exhaust with that 2" space suprizeingly it still muffles a littel and it looks legal (you will still pass emisions (depending on were you live, some states/large cites check that stuff))
8. (has cost) replace hood with lexan make shure you keep the lexan at least 6" away from top of engine (you will have to shape the lexan) (dont worry you can paint it)
9. (has cost) replace all glass with lexan (check for local legal info)
you should reduce the weight by 300-375 lbs and get 20-35 hp (mostly from ac removal) on the escort that would be going from 2468lbs to 2168-2093lbs ,lighter than a 2005 toyota mr2, and from 110hp to 130-145hp more powerfull than that 2005 toyota mr2.
the results will vary but you should take a 0-60 time from 10 secs to 7-7.75 secs, 1/4 mile from 18 seconds to 15-16 thats one high performance car
