How to put cruise control into a non-cruise car? | Ford Escort Owners Association (FEOA)
Discussion in 'Tech & Repair' started by 92wagon5speed, Apr 19, 2006.
  1. 92wagon5speed
    92wagon5speed Guest
    12
    I have a 92 wagon 5 speed i want cruise control for those long drives when i want to be a lazy ass so... what will i need to get?
    I have looked in the search area and couldnt find anything
    Thanks alot!!!!!!
  2. Asscortlx
    Asscortlx Guest
    998
    i think u need the wiring harness and the steering wheel. and the motor with the cable and the new TB plastic plate to put the cable in.
  3. billzie
    billzie FEOA Member
    2,245
    8
    288
    Athens, OH; finally moved.
    SEARCH dammit!
    And BTW, I'm tired of folks saying "don't just say search, take the time and just answer"
    Look, this particular topic is already well covered, AND, was just asked in the last few weeks AND answered.
    Bill.
  4. zzyzzx
    15,003
    1,167
    I've done this. Search for posts made by me. One of them will contain a list of parts.
    I added OEM cruise control to a 1995LX with AT. It' won't be much different from your car. Don't get a generic aftermarket cruise control. Your car has all the empty spaces, mounting points, and wiring (except one small piece in combination switch) that it needs. You will learn a lot from removing the parts from cars in the junkyard.
  5. mikescort
    mikescort Guest
    68
    zzyzzx, i searched for your name, found nothing, searched for you with some combinations of cruise control, nothing...
    I wanted to put an OEM cruise from a junkie in my car...its a Sport SE, will a cruise control from an LX work?
  6. 94scortlx
    94scortlx FEOA Member
    2,183
    4
    186
    New Jersey
  7. cdipier2
    cdipier2 Guest
    1,804
    yours is a 3rd gen im guessing. because if no then the cruise control form the Sport SE will not work in the 2nd gen. i heard that they are two different systems
  8. zzyzzx
    15,003
    1,167
    You can use parts from any 1991-1996 Escort/tracer except the steering wheel has to be from another Escort just like yours (because of air bag/non air bag issue). You can even use the vacuum servo from almost any ford made for a certain age range. SE vs LX doesn't matter, almost all the parts from a GT will work too except for one of the vacuum lines under the hood is different for the 1.9L vs 1.8L
  9. zzyzzx
    15,003
    1,167
  10. GregF422
    GregF422 FEOA Member
    3,224
    7
    288
    Seattle, WA
    The 3rd gen cruise system is an electric servo. The 2nd gen cruise system is a vacuum system. If you can't get the one specific to your generation, it should be possible to put the other on there (minus the wheel like zzyzzx said)
  11. bigh4th
    bigh4th Guest
    388
    Just an FYI for everyone about a problem I ran into on my 95 LX wagon:
    Your car may or may NOT already have the wiring for cruise in it. If you don't see a square brown plug next to your coolant resivor or 2 grey rectangular plugs under your passenger kick panel, then you DO NOT have the wiring there and you're better off going with an aftermarket system. Thats a lot easier than trying to figure out wiring diagrams and fish wires through god knows where to get a factory system working.
    Since my car didn't have the harness, thats exactly what I had to do. It took me a day and a half to do it and its totaly not worth the trouble.
    -Harry
  12. zzyzzx
    15,003
    1,167
    Good point. Mine did have the square plug near the coolant reservior, so I assumed that all Escorts had it. Next time I'm in the junk yard I'm going to look and see if there is a type of Escort that typically doesn't have it (pony, maybe?).
  13. 94scortlx
    2,183
    4
    186
    New Jersey
    [​IMG]
    is that what you're talking about under the hood? I read this and went out to take a pic to make sure i can do this!
  14. zzyzzx
    15,003
    1,167
    Yes! That's it! Meaning that's the plug for the cruise control servo.
  15. 94scortlx
    2,183
    4
    186
    New Jersey
    Success! I will be part hunting :twisted:
  16. me19875
    me19875 New Member
    2,679
    Vancouver, Washington
    maybe the pony, i have a 91 pony and i know that there are a lot of unused plugs under the hood, i havn't looked for that one, but i'm willing to bet that it's there (i hope) if it's not, i'm not going to be a happy camper
  17. 94scortlx
    2,183
    4
    186
    New Jersey
    i think it just might be a particular year wagon
  18. tllcp12
    tllcp12 FEOA Member
    24
    251
    Can you send me this picture please? [email protected] is my email. Thanks!!
  19. austin86
    689
    208
    58
    Ohio
    94scortlx was last seen Jun 7, 2013, I don't think your get those photos :(
    Also to answer OP question, a brick on the gas peddle would work.
    pextor likes this.
