1 - 20 of 24 Posts
I went to the local U wrench it today looking for some S/R struts/springs and I was wondering how to determine if a car has the S/R package. Does the vin tag in the door say something, any body badging or anything? I noticed that all the zx2's had tokico struts, but do the s/r's look different than the standard tokicos? Thanks
They probably look the same, I think it's just the internal valving that's a little different. I'm not 100% sure on this, but I thought I read that the S/R's had rear disc brakes, whereas the others did not, but I could be completely wrong on that. I'd check out the zx2 forums and ask someone there....
--sarge
check the suspension bushings (LCA, sway endlinks, etc) if they are poly bushings, chances are pretty good it's an S/R. Not sure if they are red or black, obviously, if they are red, they are poly :)
s/r zx2 early were yellow. some later years they were red and black, they have c/f shifter, a darker grey interior, blue tokico struts, red eibach springs, poly bushing, though 99 the bushing were optional and came in a seprate bag sometimes, diffrent instument cluster, i think it was silver gauges, iceman intake i think , borla exaust and disc brakes. are some of the items.
look for the S/R badge on the side of the doors. the speedo went to 150mph, the seats had S/R embroidered on them usually.
the chances of finding one in a jy are very slim, but you never know. if you do, i want you to pull the rear muffler section for me, i'll pay you of course.
actually stock stuts on escorts were made by tokico, any escort i have found worked on or seen all the stock struts say tokico.
Discussion Starter · #8 ·
I'm gonna run by there again next week, they have a ton of escorts. I got a bunch of misc interior stuff for $6 today. If I find an s/r I'll be strippin' it!
They would work...but the valving is too slow and it would wear out a little on the fast side
the ZX2 struts ARE stock struts anyways! and their valving is very very similar to the 2nd gens setup.
Try a set of S/R struts...they can handle the faster rate (and they are cheap) or see if you can get a set of the Tokico "Blues" for the Escort GT. they handle the fast rate the best of the bunch (even though they don't have the shortened piston rod like the S/R's)
im just lookin for some that will handle some abuse from bump and crap like that while giving me handleing and nice lowereing...how much would they cost..i mean u think u would find a 99+zx2 s/r in the jy anyway
not true.
the S/R struts are designed specifically with the Eibach Pro kit performance springs in mind.
The HP Blues are designed with OEM stock springs in mind.
So the S/Rs will handle higher rates better than the HP Blues.
Just to clarify:
There are 3 different Tokico struts that will fit the escort:
Stock Tokicos that came on every escort that wasn't an S/R (Black paint)
'S/R Tokicos' that came stock on every S/R (Black paint)
Blue Tokicos that are aftermarket only (tokico blue paint)
Discussion Starter · #19 ·
Checked all the local yards today including the pick and pull. One place had about 20-25 zx2's but none of 'em were s/r's. Thought I had myself some mx3 seats for $20 at the pick and pull, car had only been there for 3 days, but someone had already gotten 'em. I'm goin back next week, they're supposed to be putting another mx3 out.
Discussion Starter · #20 ·
Found a set of s/r springs and struts used for $200, does that seem like a decent deal? Spring/Strut assemblies run $80/set at the pick and pull, but I wasn't sure what the going rate was 'cause they're usually a bit under what other places charge. Sorry for all the stupid questions, just tryin to rid the scort of the caddy ride! Thanks!
1 - 20 of 24 Posts
