How-To: Change transmission oil.. the easy way! | Ford Escort Owners Association (FEOA)
Discussion in 'Drivetrains' started by nightfire, Dec 20, 2004.
  1. nightfire
    nightfire Guest
    84
    Hi everyone.
    While doing my clutch swap I had to drain the transmission, but I had a lot of trouble getting the speedometer mount off to refill it.
    So instead, I filled it from the bottom. Here's how:
    1. Go to your local hardware store, and buy a 1/2" screw-to-hose adapter. One side bolts into the tranny (in the oil plug hole), and the other side attaches to a hose. It's hollow, allowing oil to flow through it. Then, buy a 1/2" hose, preferably 8' long, and a funnel with a spout small enough to fit in the hose. Finally, buy a roll of duct tape. :)
    2. Plug the funnel into one end of the hose, and secure it with duct tape.
    3. Remove the transmission drain plug (23mm or 7/8"; careful not to strip it), and drain the oil into a pan. Let it run until the dripping completely stops. Preferably do it while the transmission is warm, but not hot.
    4. Screw the bolt end of the adapter into the drain plug hole. It won't be a perfect fit, so do it tightly enough that the gasket mates with the transmission housing to minimize leaking. Attach the other end of the hose to the adapter.
    5. Measure out approximately 3 liters (3.3 qts) of Dexron III/Mercon ATF fluid or 80/90 gear oil, and pour it slowly into the funnel, while holding it 6' from the ground. Either add it a bit at a time and raise it above your head (to create pressure), or stand on something. Once all the fluid is it, the transmission is slightly overfilled. This is fine, since in the next step, some of this fluid will escape.
    6. Hook the funnel onto something 3-4' off the ground (to prevent the transmission fluid from spilling out), and reposition the oil pan under the drain hole. Have the drain plug and some towels nearby. Then, quickly remove the hose by pulling it, and plug the hole with your finger. It will get messy. :)
    7. Unscrew the adapter with your finger over the hose hole. When it breaks free, let it drop, and plug the drain hole with your finger.
    8. Slide your finger out of the way while inserting the original drain plug. Tighten, clean up, and you're done!
  2. FordBoy4ever
    FordBoy4ever New Member
    2,262
    thats a good idea... but once you get the spedo vss out it is 10x easier than that and you dont make a mess. i understand if you dont really know what your doing and you cannot get the thing out sure but after you figure it out the first time its super simple and way easy.
  3. Josh_LX
    Josh_LX FEOA Member
    8,177
    338
    Onyourma,ma
    I couldnt ever get mine out... I filled mine this way through the reverse sensor. If i ever have to swap trannies, Im drilling and tapping a hole for a fill plug. And if i ever meet the asshole that designed that tranny without a fill plug, im gonna kick him in the junk.
  4. nightfire
    nightfire Guest
    84
    Well, I pried at that bastard for a good hour with no luck. I couldn't see it very well because I'd already reinstalled my tranny, and that didn't help. But, this saved my ass. :)
  5. red97lxscort
    red97lxscort FEOA Member
    3,850
    288
    Redding, CA.
    yea i broke my first mtx vss, had to buy a new one after the swap. my atx one also broke.. but not my fault that time. they are easy once u figure how how they come out..what part to pry on.
    -Justin
  6. mp3scort
    mp3scort Guest
    471
    My tranny has two plugs, one to drain it and one higher up to fill it. Anyone else have this?
  7. red97lxscort
    3,850
    288
    Redding, CA.
    mine has a drain plug and i filled it thru the vss fromn under the car.. pretty easy, u just have to jack the car up for it.
    -Justin
  8. MadBrad
    MadBrad BYO Plastic cutlery
    9,866
    11
    338
    Pickering, Ontario
    mine was missing the little slide on clip thing so it was real easy.
  9. GTScort
    GTScort New Member
    465
    Ann Arbor, MI
  10. Jeffescortlx
    Jeffescortlx FEOA Member
    8,421
    13
    338
    Minnesota
    I've been tempted a few times to fill'em back up this way.
    Those speedo sensor can really get stuck. I've had to destroy one to get it free.
  11. marclar
    9,032
    588
    seabeck WA
    Re: Changing transmission oil.. the easy way!
    WRONG... both the ATX and MTX use Dex/Merc III
  12. VileSpankMachine
    VileSpankMachine Guest
    31
    Why the problem?
    Why is everyone having such a problem filling the gen 2 5 speeds? Put a socket on a bunch of extentions to remove the screw holding the speedo feed bracket into the tranny, and set that screw aside. Stick a set of VICE GRIPS down there and lightly clamp them on as low as you can to the thing (as close to the tranny as possible). Just wiggle it back and forth a few times, then everything will come out as one big unit. When you put it back it, you may have to wiggle it in or tap it with a flathead screwdriver and hammer. Both work pretty well, but I've found you get a better seal if you make it go all the way back down just by turning it.
  13. Josh_LX
    Josh_LX FEOA Member
    8,177
    338
    Onyourma,ma
    Re: Why the problem?
    And what if it doesn't, like mine did?
  14. nightfire
    nightfire Guest
    84
    Exactly... Getting the retainer bracket off was easy, but I pulled at the housing for a good hour and ended up busting off pieces of the ring that sticks up. It was in there good. :(
  15. FordBoy4ever
    2,262
    twist it... if you remove the spedo cable then you can twist the whole assembly and that will help... it will come.
  16. 92sport
    92sport Guest
    53
    Take an aluminum tranny case case, a steel speedo sensor housing and mix under heat for 50k+ miles and see if theres a chemical reaction! :wink:
  17. 92sport
    92sport Guest
    53
  18. VileSpankMachine
    31
    Hurray for double posts! I guess I've just been lucky on all the 'scorts I've worked on. They always come out for me - never been able to pull one out by hand though, I've ALWAYS used the vice grips.
  19. zzyzzx
    15,176
    1,222
    I'd be more interested in a how to drain an automatic completely (including torque converter) and refill. The service manual only tells you how to drop the pan and do a fluid and filter change. To drain the torque converter it says to disconnect the cooler and connect it to a machine that does the flushing. Like I can do that at home.
  20. screwedGT92
    screwedGT92 Guest
    20
    i've done clutches on both an LX and a GT and i've had major troubles with both. i've never been able to pull the things out with a pair of vice grips.. i just usually drop the tranny then let my engineer dad have a go at it.. ;) lol, or maybe it's just the climate in ontario or something. oh well.. just my 2 cents.
    Chris
