MOD EDIT. Keep it Clean People.
---How to remove 2nd gen. LX 5spd.Tranny---
I removed my transmission from underneath;
With the help of my brother in law in a total of about 4 hours.
On a difficulty scale of 1-10 I rate ….. About a 5
TOOLS NEEDED
BASIC SET OF STANDARD AND METRIC SOCKETS/WRENCHES
32MM SOCKET FOR AXLE NUT
PRYBAR (ALWAYS USEFUL)
FLOOR JACK/JACK STANDS
IMPACT WRENCH (ALWAYS USEFUL TOO)
A FEW BLOCKS OF WOOD (2X4s will do)
::: On the ground:
Start by removing,
-Battery, Battery Tray, Air Box, Radiator (easier Access),
Catalytic Converter. (2 bolts from engine to trans. face towards the cat. So it needs to be removed to gain access to them)
-Axle Nuts (these will require a 32mm Socket and a long breaker bar to remove, or an impact wrench if you have access to one. I will warn you, I broke 3 32mm sockets trying to remove them, if you have difficulty; there is another way to remove them that will be listed below.
Now, lift the car and support it on jack stands so
That the front bumper is about 2 feet off the ground (I raised mine 27")
BE SURE YOUR JACKSTANDS ARE RELIABLE! You will be spending a good amount of time under the car.
::: Off the ground:
REMOVE,
-Tires, Rotors (calipers can stay connected, but support them with a piece of wire to avoid hanging them by the rubber hoses)
-Tie Rod Ends (don't be afraid to bang the sh*t out of them with a hammer to break them loose)
-Now remove the 2 bolts connecting the hub assembly to the strut
**** If you could not remove the axle nuts also remove the 2 bolts connecting the ball joint bracket to the lower control arm then pull the hub assembly down and out to remove it, it may take a little bit of force to remove the axle stub from the transmission. Have a friend go underneath and apply force to it with a pry bar if necessary ****
-Get underneath the car and remove the 2 bolts going from the starter to the engine, there are 2 more on the opposite side that will be removed with the tranny bolts. (I do it this way to avoid removing the intake manifold)
-Remove the 4 10mm bolts on the transmission frame cross member (2 on the bottom of each mount)
-Remove the 2 bolts going from engine to tranny that are on the bottom directly next to the bottom of the oil pan.
-Take your 2 tires and one 2x4 and stack them up underneath the oil pan without them making contact (leave about a 2 or 3 inch gap), the motor needs to tilt slightly, but could use some extra support after the tranny is removed.
-Remove the 3 bolts on the top of the transmission, connecting it to the drivers side mount.
-Now begin removing the engine-to-tranny bolts, starting with the 2 on the catalytic converter side, then the top 2, and lastly the 2 left to remove the starter, now reach in, and remove the starter. The cables can stay connected.
-Take your floor jack, with some blocks of wood on it for better balance, and jack it up to the center of the transmission frame cross member, just so it is sitting snugly, do not lift at all.
-Remove the 2 bolts on the front end of the transmission frame cross member (Mine were rusted in, and even with 2 people pulling on the ratchet, they were barely budging. I used my impact wrench for these, and even that was struggling with them. It took about 30-40 seconds with the impact wrench to remove each bolt. Be prepared.)
-Remove the 2 bolts on the rear of the transmission frame cross member, the jack will now be taking the load of the transmission (only about 60lbs, I can lift it with one hand)
-Now have one person slowly lower the jack, while the other guides it out of the top, the only real clearance that needs to be checked is the 3 long bolts on the transmission that go up into the drivers side mount. Other than that, the transmission will come down without a struggle.
Good luck!
Heres a pic so you can see more or less where the bolts are
TOOLS NEEDED
::: On the ground:
Start by removing,
::: Off the ground:
REMOVE,
Good luck!
