How-To: 1.9 SPI Hybrid | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in 'How-To's' started by Jeffescortlx, Apr 4, 2005.
  1. marclar
    9,061
    604
    seabeck WA
    the higher the better. next tiem i have the spi head off, im going to have it ground about another 40 thousandths
  2. martinarcher
    martinarcher FEOA Member
    1,545
    288
    Slippery Rock, PA
    That sucks - I was wondering if that would make for a nice N/A motor, but I guess if the parts don't move, no good.
  3. 1Sleepy93
    1Sleepy93 New Member
    4,662
    Port Orchard, WA
    Let's stick this back towards the top. There have been questions about this.
  4. fitty
    fitty Guest
    211
    2.0
    so the 1.9 head on the 2.0 block would or wouldn't work because of smashed vavles
  5. ThumpinGT
    ThumpinGT New Member
    2,924
    San Marcos, TX
    right, would not work
  6. madmatt2024
    madmatt2024 FEOA Member
    9,883
    421
    383
    Upstate N.Y.
    What would happen if you put a 1.9 HO head on a 1.9 or SPI? If I remember right the HO has domed pistons.
  7. LeraiPalmer
    LeraiPalmer New Member
    156
    Milwaukee/Tomah, wi
    Anyone know off hand what size socket to use on the 2.0L head bolts? Im going to snatch a 97 head/intake/fuel rail off on saturday at a pick n pull. Last year, i broke 3 regular sockets trying to get that head off but i forgot what size i used. This time, imma buy the stronger sockets used on air impact guns. Thx
  8. LeraiPalmer
    156
    Milwaukee/Tomah, wi
    And also what and where is the "SPI CONTROLLER"? pics anyone?
  9. madmatt2024
    9,883
    421
    383
    Upstate N.Y.
    The "SPI CONTROLLER" is where ever you put it. Its integrated into the ECU so if you are installing an SPI in a 2nd gen you will need to make your own.
  10. LeraiPalmer
    156
    Milwaukee/Tomah, wi
    found out its 13mm or 1/2 socket for head bolts. Anyway ill do a search on how to make this "SPI CONTROLLER". If i dont find anything, i shall be back to ask you experts. I didnt think i would need it if im just swapping the head/intake.
  11. madmatt2024
    9,883
    421
    383
    Upstate N.Y.
    The SPI head on the 1.9 bottom end won't work right unless you are going to turbo the engine. The CR will be too low.
  12. LeraiPalmer
    156
    Milwaukee/Tomah, wi
    i realize that. I bought my turbo last wk. Im just getting all my parts together. Since ive joined this site ive read that the 2.0 head on the 1.9 bottom is the best combo. So if theres any other lil thing a take off that 2.0 engine, let me know. I want to do it right the 1st time.
  13. redneck_racing
    redneck_racing FEOA Member
    213
    5
    128
    Oregon City, Oregon, USA
    this should be stickied...this helped me out in my old hybrid build soooo much
  14. slammed escort 95
    slammed escort 95 FEOA Member
    47
    18
    I know this is a very old post but im doing this swap and noticed my 1.9 fuel rail has two fuel lines running to it im sure one is feed and one is return but the 2.0 only has one at the fuel rail so where do I hook the second line too
  15. ShakeZilla19
    ShakeZilla19 My name is ^^^
    3,172
    666
    363
    Toss the 2.0L SPI rail and keep your old 1.9L fuel rail.
  16. Jeffescortlx
    Jeffescortlx FEOA Member
    8,421
    13
    338
    Minnesota
    Nope, 1.9 rail doesn't fit the SPI intake manifold.
    Only option is to use the 97 rail.
    ShakeZilla19 likes this.
  17. ShakeZilla19
    3,172
    666
    363
  18. slammed escort 95
    47
    18
    my spi hybrid turbo build is done but Im not sure if my low idle is normal for this build it idles at 300 to 400 rpm in park when I put it in drive it idles at 500 input would be greatly appreciated I have all the vacumn lines hooked up except for the one on the very end of the intake manifold not sure where to hook this to because the evap and egr system is different than the 95 escort going to the 97 2.0 head please help
  19. madmatt2024
    9,883
    421
    383
    Upstate N.Y.
    If nothing is hooked up to that port then you need to plug it. Everything that hooked up to the 3 way port on the top of the 1.9 should attach to the port on he side of the 2.0.
  20. slammed escort 95
    47
    18
