1 - 3 of 3 Posts
Dont hold me to this. But i believe you can shave off about .44 thousands. But that be getting close to the valves i think. It would be better to just get new pistons and etc. If your wanting to go higher compression.
your best bet would be to look up the stock head height in a helms or haynes and check the maximum amount you can shave off, and then do a little less than that.
Next thing would be to get some pistons which could raise your compression... or a full on stroker kit.
1 - 3 of 3 Posts
