How many miles on your factory starter | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by gnx547, Jan 7, 2013.
  1. gnx547
    gnx547 FEOA Member
    428
    168
    How many miles do you have on your factory starter?
  2. ShakeZilla19
    ShakeZilla19 My name is ^^^
    3,154
    654
    263
    My starter is original ~165K
  3. EscorGo
    EscorGo FEOA Donator
    3,006
    138
    213
    Wichita, KS
    Ditto. 275K
  4. zzyzzx
    14,755
    1,103
    Original at 239K.
  5. Intuit
    Intuit FEOA Member
    7,481
    891
    Southwest Ohio
    >280k on factory starter and engine. Replaced alternator @250k - brushes damaged commutator.
  6. FordMan59
    FordMan59 FEOA Member
    4,513
    409
    333
    Russellville, Kentucky
    I think the original starter on my '88 Pony lasted till around 300K and is still on it's second starter at 518K. As far as I know the starter on my '94 is original with 193K. The '02 SE still has the original starter at around 132K and both the '97 wagon and '88 GL still have original starters at under 100K each.
  7. white-lightning
    white-lightning FEOA Member
    2,896
    186
    Salem, VA
    Mine has 148k on it. I did clean and re-grease it when I replaced the broken bendix gear back in june.
  8. denisond3
    9,934
    2,697
    I know the starter on my 92LX was original at 192k, as the car had been in the family since new. I replaced it at about 210k miles, though the real problem was probably a bad ignition switch. With the other 4 Escorts in the family, they all were bought well used, and I dont know if the starters were original or not. With two of them I replaced the starters that were on when I bought them, since I knew the cars each had over 250,000 miles on them; and I wanted reliability for the family members using them.
  9. gb_astro
    gb_astro FEOA Member
    100
    14
    168
    Iowa
    Got 128k on mine. Still works great.
  10. Rocket
    Rocket FEOA Member
    78
    156
    292K :D
  11. WOTEscort
    WOTEscort FEOA Member
    123
    17
    168
    115k as of today... factory starter.
  12. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,140
    942
    363
    Vancouver Island, Canada
    A little over 160.000 miles, but I did replace the solenoid with a good used one. I replaced the crappy steel nuts on the big electrical posts with brass ones.
    I also gave the starter a complete teardown, inspection and reassembly a couple years ago. It was still excellent inside, lots of life left on the brushes.
  13. zzyzzx
    14,755
    1,103
    Stainless steel would have been better then brass.
  14. millball
    millball FEOA Donator
    1,329
    250
    233
    Southern AZ
    [quote="zzyzzx"
    Stainless steel would have been better then brass.[/quote]
    Not from a conductivity standpoint.
  15. Egnorant
    Egnorant FEOA Member
    551
    48
    278
    Deep East Texas
    210K
    Mine lasted 210,000 miles but I had it delivering pizza. Often 40 starts per day! Odd thing was that when I tested it it off the car it worked fine.
    When I rolled it to the position it would sit in the car it failed. Roll it to any other position it worked fine! Pulled one off my parts car and still strong at 377,000 miles.
    Bruce
  16. parkspro
    parkspro FEOA Member
    43
    158
    Near Gettysburg, PA
    I just had to change mine at about 95k. I'm feeling kind of jipped now. :p
  17. Joey_Twowagons
    2,140
    942
    363
    Brass is, as said, better electrically. Plus it is more similar to the copper post so less chance of galvanic corrosion. Strength isn't an issue here, the copper post is the weak link.
  18. zzyzzx
    14,755
    1,103
    The nut isn't an issue when conducting electricity here. It's the bolt that does. In so far as the what the post bolt is made of, you do have a good point, but I have no idea what it's made of since I have never taken a starter apart and with as much dirt and corrosion it probably has on it can you be sure what it's made of?
  19. zzyzzx
    14,755
    1,103
    You should. Starters are often easy to repair, just like alternators.
  20. Intuit
    Intuit FEOA Member
    7,481
    891
    Southwest Ohio
    Re: 210K
    Some motors have wider gaps between the commutator plates. Sometimes the brushes wear with a sharp corner, get caught between the commutator plates. Sometimes the brushes wear in a manner that leads to reduced surface-area contact with the commutator. Less contact surface area means less amperage throughput, less torque generated; insufficient torque to get past the first compression stroke.
