how many hp? | Ford Escort Owners Association (FEOA)
how many hp?
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by 97LxGrandmaGreen, Apr 2, 2007.
  1. 97LxGrandmaGreen
    97LxGrandmaGreen Guest
    7
    Hello
    i have a 97 lx
    and was wondering about the horsepower rating
    if anyone could help that would be great
    thanks
    jeremy
  2. 98_Jim
    98_Jim FEOA Member
    385
    16
    268
    110 Horsepower @ 5000 RPM
    125 ft/lb Torque @ 3750 RPM
    It's in the owner's manual. You can download one for your car by clicking HERE
  3. Escort671
    Escort671 FEOA Member
    2,201
    286
    San Antonio
    and just to clarify that is to the crank, not to the wheels.
  4. GregF422
    GregF422 FEOA Member
    3,224
    7
    288
    Seattle, WA
    Ha.. yeah. The wheels are much less than that, espicially if you have an automatic.
  5. itr0754
    itr0754 Guest
    130
    So what's the expected power to the wheels on a 98 automatic ??
  6. JonsZX2SR
    JonsZX2SR New Member
    99
    Connecticut
    Estimate about peak 87-89 WHP for the ATX and about peak 92-94 WHP for a MTX in 4th gear on a mild dry day.
    If this sounds depressing a stock ZX2 puts down about 104-108 WHP for the MTX and that is rated at peak HP at the flywheel. The Zetec can get into the mid 130 WHP range with bolt-ons, but remember it has 4 valves per cylinder, much more aggressive cams and a 9.6 to 1 CR.
    The OEM cams on the SPI are the big limiting factor (185I/188E deg duration at 0.050" with 0.402" lift. In comparison the Zetec has 214I/206E deg @ 0.050 with 0.366I/)0.338E lift. The lower lift reflects the 4 valve configuration.)
    Exhaust, UDP, tuning could add another 5-8 WHP without going inside the engine. You aren't going to get much beyond 100 WHP unless you do head/cam work, add a bit of nitrous oxide or turbo the engine.
  7. GregF422
    3,224
    7
    288
    Seattle, WA
    So a longer duration cam with maybe a little more lift combined with a compression ratio bump (say, thin gasket or decked) to try to get up to 9.5 or 9.6 and the SPI could be reasonable close to the Zetec? Maybe? A little? ...Please?
  8. malone1453
    malone1453 New Member
    1,489
    new jersey
    does anybody make performance cams for any of the cvh motors??
  9. Escort671
    2,201
    286
    San Antonio
    you get some off escortfocus.com, or I think Paeco makes some, or you can your reground or buy ones to get custom ground.
  10. PonyExpress
    PonyExpress New Member
    4,128
    tons over in the UK.
    best to just have your stocker (or a junk yard spare) reground.
  11. 97LxGrandmaGreen
    7
    Thanks guys
    I have a ATX so 89WHP is pretty depressing.
    What is the current CR for a 3rd gen?
    Thanks again guys
  12. Escort671
    2,201
    286
    San Antonio
    9.7:1 I think there broseph... its 9 point something
  13. jet-lee
    jet-lee Guest
    780
    SPI = 9.2:1
    Zetec = 9.6:1
  14. Escort671
    2,201
    286
    San Antonio
    I knew it was 9. something :)... 9.2:1 good for boost, so that makes the SPI hybrid what 8 something to 1
