How do you separate the black reservoir | Ford Escort Owners Association (FEOA)
Discussion in 'Drivetrains' started by garyd, Apr 18, 2020.
  1. garyd
    garyd FEOA Member
    406
    23
    278
    On power steering pump from the pump on a 1.9l 2nd gen escort. Found a new pump but housing is broken
    I also need to know how to press new one on
    Thank you
  2. garyd
    garyd FEOA Member
    406
    23
    278
    My pump is bad so I need a new one.
  3. denisond3
    10,125
    2,828
    Once you have removed the threaded fitting where the fluid comes out, the housing should slide off - but will give you some resistance.
    I always get the pump that comes with a plastic reservoir included. That save me from trying to slide the old one off, evenly so as to avoid breaking it. You will need a new pair of "o" ring seals when you assemble the reservoir to a different pump.
