*opens up car-theft handbook*
Rip off the peice of trim under the steering wheel. Inspect the ignition wires on the ignition switch tumbler. Decide which ones are grounds, which ones are hot. Now, since you turn the tumbler clockwise to start the car, the wire attached furthest clockwise along the tumbler should be the starter. The ones before it should be the run wires. Rip the wires out, twist the exposed wire from the run wires and check to make sure that the test lights come on in the dash. Now, try grounding the start wire to the metal frame under the steering wheel. If nothing happens, touch the start wire to a hot wire.
Now, don´t go stealing any cars.. :-Y It´s not as easy as it sounds.
Beaverboy
[ This message was edited by: Beaverboy on 07-04-2003 11:36 ]
