Hose to PCV valve | Ford Escort Owners Association (FEOA)
Hose to PCV valve
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by zzyzzx, Mar 25, 2006.
  1. zzyzzx
    15,209
    1,230
    The one labeled part number F4CE-6758-AB (at least on a 1995LX) has a L shaped vacuum fitting on one end where it goes into the intake. Anyone happen to know the size for a replacement? Looks close to 1/4- 3/8, but you never know. I'd post a pic, but the batteries for my digital camera are being cherged right now.
    Knocking Diesel likes this.
  2. highanddry
    highanddry Guest
    8,446
    5
    It doesn't really matter what size of hose you use. Just make sure it isstrong enough (for example fuel line) that it won't collapse under vacuum. The PCV valve itself will regulate the flow, so the ose size is essentially irrelevant, provided you can attech the PCV valve to it and secure the hose itsefl the vacuum tee.
  3. zzyzzx
    15,209
    1,230
    Specifically, I am referring to this (now that I have a picture). You should see that it looks picnhed.
    [​IMG]
  4. zzyzzx
    15,209
    1,230
    You can see if you look at the back it's collapsed:
    [​IMG]
  5. zzyzzx
    15,209
    1,230
    OK, I had to go to severla auto parts stores (dealers closed on Sundays). There is no PCV Elbow made specifically for the Escort (meaning in any of their catalogs). However, one auto parts store person said that he had run into this problem before and gave me a Motormite Help 47029, which is made for Chryslers, and said that it would work. We even test fitted it in the parking lot. It looks like this:
    [​IMG]
    techman_hou likes this.
  6. 93scortluv
    93scortluv Well-Known Member
    3,986
    171
    315
    Rhode Island
    I used fuel line hose on mine. Simple and cheap and have had no problems from it.
  7. DAPSi
    DAPSi FEOA Member
    222
    266
    Virginia
    I bought a new one from the dealer. It comes together with the plastic tubing. I think it was $15.
  8. ryanrules
    ryanrules FEOA Member
    5,209
    338
    Pennsylvania
    glad to see you got it worked out!
    i had something like that one time, and i just cut off the bad section and put it back on.
  9. zzyzzx
    15,209
    1,230
    Dealer would have been my first choice, but I didn't find this until Saturday afternoon and it was too late to go to a dealer.
  10. zzyzzx
    15,209
    1,230
    The crappy aftermarket replacement has already failed! I'm off to the dealer tommorrow. I'm also going to write a nasty gram to the company that made the crappy replacement part.
  11. therieldeal
    therieldeal FEOA Member
    8,622
    19
    338
    Northeast CT
    mine crapped out like that on my wagon... i just pocketed one at the junkyard :)
    -jon
    Nathan84382 likes this.
  12. scottwiiki
    scottwiiki Guest
    447
    I just told Dink at autozone it was a straight hose 2 feel long. He gave it too me, and I bought hoseclamps. It fits fine, and it doesnt have to run over the engine like it did before. haha
  13. zzyzzx
    15,209
    1,230
    What size hose did you buy? The first dealer I called wants $34.09 for one. the second one wants $21.73. Rubber parts that old aren't the type if thing I get from a junkyard, uless you got one off of some other new car and it happened to fit anyway.
  14. Abarthel
    Abarthel New Member
    1,849
    You ever see the car idle with it off? Its crazy It bobs up and down at 500RPM.
    I used electreal tape, works good. about every month I have to put another layer on.
  15. therieldeal
    8,622
    19
    338
    Northeast CT
    i tried tape but that didnt work at all. just grab a couple of them from the JY. hell, they are free. keep a spare in the glove box in case it lets go again :)
    -jon
  16. Josh_LX
    Josh_LX FEOA Member
    8,177
    338
    Onyourma,ma
    Hell yes.... Minehad a crack in it and it took me forever to find the sombiatch. It idles like utter crap for about 2 months.
  17. Abarthel
    Abarthel New Member
    1,849
    Mine just flat out broke, Its on teh list o-crap to fix.
  18. pyro_maniac69
    pyro_maniac69 Guest
    749
    which with these car seems to be pretty long
  19. zzyzzx
    15,209
    1,230
    Alternate fix provided by Wolff
    [​IMG]
  20. crackerloco
    crackerloco Guest
    19
    An old spark plug boot worked great for me- repair cost $0!
