Hose leak by ac compressor | Ford Escort Owners Association (FEOA)
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by austinbarclay, Jan 16, 2020.
  1. austinbarclay
    austinbarclay FEOA Member
    6
    I have a 2002 ford escort zx2 just bought it and about 133k miles. There’s a leak coming from a rubber hose that goes into a crimped hose by the ac compressor on the serpentine belt. I have found very little information on it some people say it’s a normal heater hose and some people say it’s a line for the transmission cooling. I just want to be sure before I replace the hose I know what is going to come out of it so I’m not a sitting duck with no transmission fluid. Any information helps thank you!
  2. Swift
    Swift FEOA Donator
    475
    89
    278
    Any chance to get a pic?
  3. austinbarclay
    6
    I might be able to get One real quick it’s easier to see jacked and the tire removed
  4. austinbarclay
    6
    Here’s a picture of it
  5. austinbarclay
    6
    And the hose comes from the radiator right above the lower radiator hose from the passenger side
  6. denisond3
    9,934
    2,697
    I dont have a 3rd gen nor a DOHC Escort, so am just making a wild guess.
    On my 2nd gen Escorts, the fittings for the transmission fluid going into/outof the radiator side tank are banjo bolts, and the join where the rubber hose turns into a metal tube would have a swaged ferrule, not a screwed hose clamp as shown in your photo.
    A common reason to have a hose going to the side tank of the radiator would be a return line from the heater; thus it would have coolant in it.
    I dont like to have old coolant carrying hoses on my Escorts. Since I got each of mine when they were far older than ten years, an early maintenance job was to replace all underhood hoses carrying coolant.
  7. austinbarclay
    6
    thank you
  8. austinbarclay
    6
    This is an update and slightly solved reply to my post
    the heater hose in question and pictures is in fact a heater hose for the heat in the cabin. Today I finally took it off to drain whatever fluid came out and antifreeze came out however I have not fixed it I ordered a heater hose I believe to be the right part tomorrow or Monday I will pick it up and see and confirm but to stop the leak I have a straight heater hose from line to line however it is kinked so no heater right now
  9. denisond3
    9,934
    2,697
    Glad to hear the feedback about your problem.
    austinbarclay likes this.
  10. 04Svt
    04Svt FEOA Member
    706
    217
    103
    Yes , that picture is in fact a line that goes to the heater.
