Get this, my friend came by Sunday with his 2002 Acura RSX Type-S - very sweet car. We were going to mod his car with uprated brake pads and color his calipers while in there. Because he´s got the factory body kit, and the bigass sub box in his trunk, we couldn´t use the stock factory jack to engage underneath the side sills. He uses a 3 ton floor jack. Well underneath the car up front is a cross-member with an arrow pointing to the jack recess. We engage the jack and begin lifting intending to fit a pair of jack stands underneath. Mind you, we did everything by the book - chocked the wheels, brakes on, properly engaged the jack, etc. The car is about one and a half feet in the air and we´ve just gotten out from under it trying to place the jackstands. I give it one last lift and there´s this awful cracking sound and the car´s suddenly sitting on the ground - rotors all dug into the dirt and gravel and get this, the hood is popped open. It´s a sickening moment and all I can think of is that we just grounded this $25K car and have no way of lifting it back up.
Long story short - after an hour the tow truck comes and then have to dig under the car to get a jack in there. In the end, it looks horrible, hood sticking up 3 inches. But the only damage is that the bottom crossmember which connects to the radiator got forced upwards, causing the hood latch mount to shoot upwards. So while the car´s hood can´t close now, there´s NO other damage.
I can´t tell you just how digusting it was seeing this car stuck in the dirt. According to the tow truck guy, he thinks we did everything ok given that we couldn´t use the factory jack - his opinion of the Acura´s front jack recess is that it´s been miscast from the factory - it was rounded, not flat and so when raised, the jack would slip out. So my friend is going to try to pursue a warranty claim being that the stock jack was unable to be used due to bodykit (installed by Acura), and the bad design of the front crossmember jack slot.
