1 - 3 of 3 Posts
I've told this is probably a clock spring issue, and been given some diagnostic instructions to run. If this is a clock spring issue, is it easier to just replace the entire airbag assembly? I was told Ford Dealers will not service this and won't sell just the clock spring, and that my best bet would be getting once from a junkyard. Well I've found airbag assemblies online so I was thinking I might just replace the whole thing.
when you press the horn do you hear a relay click somewhere under the dash?
also, check the fuse. sometimes the common stuff trips us up!
1 - 3 of 3 Posts
