first off, WOW, I've been lurking for only about 30 minutes and searching for key words and I feel like I know 10 times more than I previously did. You guys are a wealth of information!!
With that said, I have a broken 99 escort that needs some help =/
It has 130k on it and it died on my fiance at the gas station after being driven ~20 miles from her work. I just simply wouldn't crank over and start and when it did start it only lasted for like 5 seconds and it sounded like it was tearing up the engine. bad news!
I took it to a small shop who barely looked at it and said i was SOL and said it was dead. Didn't charge me so i took it to a local ford dealership. they charged me an arm and a leg IMO and they didn't even take off the intake manifold (that's the part w/ cam and valve stems right?) basically they said my engine had little or no compression on any of the valves and was unfixable they thought.
I've had this car for 10 years and love it dearly. I've kept it up w/e required maintenances for the life of it so I'm totally wanting to fix it up myself. I've had the timing belt and water pump replaced @ 100k.
Sorry if this is getting long.
Based off what I've just learned from you guys and gals is my engine is a non-interference (which is good) and that these SPI engines can sometimes drop valve sleaves. I'm wondering how bad that could mess up the pistons.
My other theory is that possibly when the local dealership changed the timing belt at 100k, they didn't replace the timing belt tensioner and that part might have failed, making the timing belt loose enough to jump a tooth and mess up my engine. I'm assuming that would cause little/no compression but would that also make the engine sound like it's tearing up inside? If you got this far reading my novel
thanks and any insight you can give me would be greatly appreciated. Cheers!!
btw, a totally different local shop has a 98 2dr escort for going to the auctions and he said the engines are swappable? is that right? i think he said that engine was mechanically sound so that might be another idea?
