as the tittle says i experimented this problem, when the car are cold it´s worst, but only when load, no on idle, the idle is fine, very fine.
but i´ve notice that it´s worst when i desacelerate after a mid range of rpm, tomorrow i´m going to check all the sensor and codes at my friend´s workshop.
last month i went to autozone and found a bad o2 (before cat) so i replaced it, then the car runs good the next 2 or 3 days, but it start when the car are cold and stop when warm (normal temp).
but since last saturday it start to shutter anytime, it´s intermitent.
last sunday i drive on a highway, and notice that when the car are cold because of the speed the horse came back, like missfire, then when o stop the car it warm up and start again the car sputter again and you can smell the gasoline, to much rich the a/f mix.
what could it be?
fuel pump OEM, after 265000 km
new upstream O2
NGK sparkplug wires have 2 years
Autolite platinum spark plug have 6 month, i check it today and they are black (rich that why i replace the O2)
best regards
best regards
what could it be?
new upstream O2
best regards
best regards
