1 - 5 of 5 Posts
Hi
I am new and I have a stock 95 Escort LX and the rear spoiler is loose. I have taken the panel with the light and stuff off the hatchback on the inside to try and tigten it, but no luck. I ahve looked at a few other Escorts and noticed the same problem (exception for about one). Any help appreciated.
Thanks
John :)
It is loose on the left and right sides. The middle is good. If I bturn my radio up a bit I can hera it rattle abit, and it also rattles when I go over a bump, its not too much ofa concern but the roads here in Canada have alot od bumps, so its strating to annoy me.
Thanks
The mounts underneath the pillars on the left and right side are crap. To get the wing off, you just remove the screws at the third brake light and the ends just pop out of the clips theyre fastened to.
The best thing Ive found to fix it is to use a silicone adhesive to glue it back down. It works great, waterproofs and keeps it from rattling. Just do it when you wont be driving the car and use some weight on the wing to keep it down while the adhesive dries or tape it down tight. Good luck.
1 - 5 of 5 Posts
