Hey all, it's been a long time. Used to hang around quite a bit, but sometimes life gets the best of you and you have less time for internet "procratination."
Anyway, my '97 LX wagon (2.0L SOHC) has developed a noise that seemed initially to just be a classic failing or misaligned pulley kind of thing. But that just doesn't seem to be it. Forget the serpentine belt area as running it with serp belt off is irrelevant. Same noise.
The timing belt kit (belt, tensioner water pump) is Gates and only like 45-50K old. Removed belt and tensioner. Spinning water pump with no belt - no sign of a problem. No weeping, no noise or roughness, no shaft play, etc. Simply no sign of a problem. Same with the tensioner pulley which was removed and played with. Smooth and quiet. Sprayed water onto the belt while running. Fussed with the tensioner while running. No changes. Ran all over everything with a stethoscope and a dowel. The sound just telegraphs so much - it's like everywhere and nowhere. I did pay special attn to tensioner and water pump probing for sounds, but all they do is hum.
Once the serp belt was off and it continued I figured water pump - and I could still believe that. But I try not to just throw parts at things and the water pump doesn't appear to be a problem.
Anyway, if you have 10 secs can you give it a listen and let me know if it sounds familiar?. Thanks!
