How do I get the two pins out of the cylinder housing with out having to take the whole mess out.problem is got stranded at gas station.key turned and cylinder broke no power to start no nothing
Ive got the plastic covers off the steerig column switch exposed there are 2 pins holding the cylnder in once I can remove them the lock should come straight out with the key . not sure what the pins are called .kind of metal dowels with a slit they were taped in and are under tension Help
