Hey everyone! I run a mostly stock '92 pony on a 1/4 paved track, with these specs: 1.9L four, 5 speed, enduro type cage, 175/70R13 tires all the way around (used sumitomo HTR200 in front and right rear, and a "junkyard" right rear.) I'm running 50 P.S.I. in the right front, 40 in the left front, 30 right rear and 27 in the left rear. It has maximum allowable camber in the front, and 1/8" toe out. I'm running a straight thru exhaust (no cat, no muffler), a left rear spring that has two coils missing from being broke, and the right rear has all coils, but two are broke apart. It has stock brakes and no air filter.
I want to run it on a 1/3 dirt track, with low banking, and was wondering if I could have some tips? I already plan on switching to 14" tires since it's a longer track, and will be reinstalling the air filter. What should I run for tire pressures? Should I run staggered tires for the front so that it helps turn it? Should I change my toe setting? Should I do anything to the suspension? Anything else I can do to increase my times?
Thanks!
Thanks!
