Engine - HELP!!! Throttle body vacuum hose | Ford Escort Owners Association (FEOA)
Engine HELP!!! Throttle body vacuum hose
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by Logix727, Aug 21, 2019.
  1. Logix727
    Logix727 FEOA Member
    5
    Hello I need the part number or more specifically a replacement part for the hose that goes from the back/bottom of the throttle body to the pcv canister. Mine collapses/leaks and causes the motor to idle/run weird.
    "f8cz6853aa" and "f8cz6853Ba" are the two part numbers i found but it does NOT look like the part i need
    help a brother out!
  2. Swift
    Swift FEOA Donator
    497
    102
    293
    I just bought plain old hose from autoparts store
    Logix727 likes this.
  3. Logix727
    5
    I did that but it collapses because of the angle maybe i should take the canister off? Thoughts?
    also do people ever put breather filters on these and take off the little thing sitting on the uh valve cover?
  4. Swift
    Swift FEOA Donator
    497
    102
    293
    I didnt really have any sharp angles, honestly the line under the throttle body i left a out a foot longer than original
    For the valve cover hose i believe i used some power steering line from the parts store, it was not easy to bend
  5. Logix727
    5
    ^ dope u rock ya i just tried regular hose off the nipple of throttle body it closed up as soon as i gave it some gas
  6. Logix727
    5
    Longer hose was the trick
  7. Swift
    Swift FEOA Donator
    497
    102
    293
    Glad you got it. Might as well replace all the vaccum lines while you are in the area
  8. Logix727
    5
    O
    I appreciate it!!!
    Hey one more question on the throttle body there's a nipple to the left of the PVC line where does that go to?there's essentially 3 but the one on the end only has air sucking in when I put my finger on it it runs better I think it was capped but the cap is missing?? Pls advise
  9. Swift
    Swift FEOA Donator
    497
    102
    293
    I really only know sohc, so it's better in this case to wait for someone with more knowledge than me.
