1 - 9 of 9 Posts
...i need help on how the hell you take off the stock radio of my 95 escort lx...pls. gimme some help asap. thanks alot guys.
well there r about 2 ways that i know of either buy the tool or you can take 4 nails long but small put one in each hole( one in each corner) jam them in and all at same time ( i used construction nails) and pull out nothin 2 it
You can pick up the tool at walmart or any auto part stores or just take a coat hanger and cut it and shape it into a u.Stick both into each side and pull.
Well, I did mine with the coat hanger, wouldn't recommend this - nails sound like a good idea (could probably push them in at the same time with the piece of 2X4 that'll be sitting around with them. If I wanted to do it the easy way though, most places I've heard sell them for like $10, cause apparently there is a large risk with coat hangers that something will get stuck, and well, then it's just messy. If you don't want the old deck though, I think it would be kind cool to just take a hammer to it, and maybe a chisel *not responsible for and damage*.
you can always just remove the center of your dash and manualy push the fingers in (ive had to do this, but my dash was already halfway apart cuz i was doing the heater core) so dont worry about fubaring anything forever you will be ok.
yeah i can get the tools for under 4 bucks at walmart
THE REMOVAL KIT FROM WALMART IS LIKE 4 BUCKS!
1 - 9 of 9 Posts
