1 - 2 of 2 Posts
Well here is my problem.
I have a 1993 with the 1.9L. It is ideling very bad and when I try to accelerate it just sputters horribly and backfires really bad. After a few seconds it will accellerate normally and then go back to sputtering and backfiring really bad. The number 4 or 1 plug (the one all the way to the right on the drivers side) tip was melted all the way off. All the other plugs were fine. The check engine light comes on but will cut off when I stop to hook up the codegrabber. What could be causing my trroubles.
I have changed the coil pack, wires, plugs, injectors, and air filter.
1 - 2 of 2 Posts
