1 - 9 of 9 Posts
Hi there:
A/C stopped working on my 95 Escort GT. It was working fine before I off the car at the gas station. No AC at all after restart. AC light works, I checked the pulley and it does turn when i switch on the AC. A mechanic say both the clutch and compressor is bad, but still full of refridgerant. I kind of doubt what he say. Any idea? BTW, where is the relay if I want to check it?
Thanks
Well If your clutch is engaging and turrning the pully there is no point in checking the realy, because it obviously works. When you say your A/C doesn´t work what exactly do you mean?? There are a lot of symptoms that make people say their A/C doesn´t work. Is it just not cold any more? Does it blow air or not? Give me the specifics, and I might be able to narrow it down for you.
Hi there:
Well... there´s simply no cold air anymore.... relay should be good as the center of the ac clutch will turn if i turn AC on.... as for the ac clutch... it should still be ok unless there´s a way for it to turn without actually turning the compressor.... correct me if I´m wrong..
Any help appreciate it....
1 - 9 of 9 Posts
