1 - 6 of 6 Posts
Does anyone know... Under the hood of my 94 EGT next to the VAF, is the distribution block for like MAIN, and HEAD, COOLING FAN and also some relay for the fuel injectors, does the 80AMP MAIN block pull out?!??! Mine blew, I tried to pull it out like all the others do, the yellow and pink ones, 30amp and 40 and it will not come out, so i did it harder, now it all pulled apart but the legs are still there i cant put another one there, cuz there are still pieces in there?? Any ideas?!?!?
You found the tricky fuse... If you´ll notice, there´s a bolt going into the left leg of the fuse. Well there´s one on the right side too, so you will have to unbolt the entire fuse assembly to be able to get to the right side. Unbolt that, and only THEN will the fuse come out. It´s a pain I know, that Ford did it that way. But it´s relatively quick once you´re in there.
hey donny, mine did that too a while back, for a quick and temporary fix I used a pice of like 4 gauage speaker wire ti rug it to move it. I don´t recomend it for to long cause the wire tends to move and will come lose and cause you problems. But to really fix it do what zmax said. It is really easy to do when you have to right tools.
LOL yes, what a pain, But I have to go do that soon, I also need to find a new 80AMP fuse I guess auto stores carry them. Thanks people for the info, Lol i should have looked at the repair manual, but i was in a harry and like wtf?? what is this stuck in here!!
LOL
1 - 6 of 6 Posts
