Howdy, first time poster.
I've got a 98 2L automatic with 148,000 on it.
I replaced the timing belt and waterpump on the car in a foray in "preventative maintenance" and failed to put the gasket on the water pump on correctly. If you haven't guessed yet I lost all the coolant in the car, overheated it, and blew head gasket/cracked block/etc.
It was bubbling exhaust gas out the radiator, coolant out exhaust, and after warming up would stall on idle.
I replaced the head gasket by the book, new head bolts, had the head pressure tested and resurfaced. and generally cleaned everything up.
I got it all back together and it seems to run as well as it did before this all went down. However I'm still getting some water droplets out the exhaust pipe after it warms up. When I pull the dipstick out it seems like there's alot of gas coming out, I don't know what a normal amount of blowby gas looks like with the dipstick out.
I then ran the nanotechnology head gasket repair gunk through the cooling system per their instructions; not sure if I noticed any change though.
I took a compression test, cylinders 1 through 4 read:
145, 144, 131, and 169; after a few squirts of oil they read 165, 165, 160, 200.
This seems very good.
I'm new to all these procedures and am not sure what is acceptable and what isn't.
Do I still have a breach in the water jacket, possibly in the block, that is letting some small amount of water into a cyclinder? Could I be getting those compression results and still have some kind of crack or I didn't install the head gasket correctly?
Any advice or suggested next steps would be greatly appreciated.
