The trim panels you need to remove to get headliner out are all held in with spring clips. Even pressure on panels will allow for them to "pop" off. If the clips pull from the plastic panel, it's ok, just pull the clips and install them back on the panels prior to reinstalling panels. I have pulled out many headliners in these cars, but never had to do one with a sunroof.
