Head swap | Ford Escort Owners Association (FEOA)
Head swap
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by Robby-joe, Mar 4, 2019.
  1. Robby-joe
    Robby-joe FEOA Member
    157
    25
    128
    Blew a gasket, so I'm putting on my new to me ported and polished head(also cammed with 99-00 cams, Volvo springs) got all my gaskets and new bolts in today. Any tips/tricks, pointers, advice for someone who hasn't been into this block before?[​IMG][​IMG][​IMG][​IMG]
    Sent from my ONEPLUS A6013 using Tapatalk
  2. Gamer92
    Gamer92 FEOA Donator
    3,441
    986
    263
    Southern Indiana
    Not sure if GT uses reusable head bolts or tty Bolts but you might want to check the condition of the Bolts if they are resusable.
    Did you find out why the gasket failed? Was the block checked for any uneven spots?
  3. Robby-joe
    157
    25
    128
    Bought new bolts, and I got it too hot, had cooling system issues, and I'm sure that's why, but didn't really seem to bad till I did a coolant flush after doing all my hoses and putting in a new rad.
  4. Gamer92
    3,441
    986
    263
    Southern Indiana
    Make sure you get all the old gasket off the block surface and maybe put some towels or rags in cylinders to keep any debris out of there. I like to use a small razor blade scraper but be careful not to scratch the deck.
    denisond3 likes this.
  5. Robby-joe
    157
    25
    128
    Have razor scraper and green brillo pads to clean the deck. Clean rag and a blower on the compressor. All the hand tools I need.
  6. Robby-joe
    157
    25
    128
    What should I put on the new bolts, assembly lube? Antiseize? Motor oil?
  7. Gamer92
    3,441
    986
    263
    Southern Indiana
    Motor oil
    You’ll need some thread chasers to clean out the head bolt holes and a compressor with blow gun to clean out the holes. I like to use brake cleaner to clean them out and then blow it out with air gun
  8. Robby-joe
    157
    25
    128
    Thanks
  9. Gamer92
    3,441
    986
    263
    Southern Indiana
  10. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,343
    1,068
    Vancouver Island, Canada
    Work carefully and methodically.
    Figure out why the old camshafts rusted up.
  11. Robby-joe
    157
    25
    128
    Water in the oil, sat for 6 weeks like that
  12. Joey_Twowagons
    2,343
    1,068
    Hmmm, I hope the crankshaft journals are okay. They probably are, since as a rule rust seems to only form on surfaces exposed to air, when there's both oil and water present.
  13. Robby-joe
    157
    25
    128
    After clean up, forgot to get a before, cyl 2 and 3 were wet, 1and 4 lots of carbon. Mls gasket was on there, it seems to be pulled apart on the exhaust side on 2 and 3[​IMG]
  14. Robby-joe
    157
    25
    128
    Idler and tensioner pulleys replaced, gonna pick up an impact tomorrow to get the crank pulley off. Gonna clean it a day though.
  15. Robby-joe
    157
    25
    128
    Sorry for the late reply, got er done that next day, she runs like a top. A bit more pep in her step, and fluids stay where they belong. The heat delete isn't the greatest, but oh well.
