I am going to start the process of replacing the head assembly on my 1999 Escort wagon. Of course it has the 2.0 SPI engine.
First question is how long should this job take? I am hoping I can teardown and prep tonight and re-assemble tomorrow night. I figure I can spend about 6 hours per night. Think that is enough time. I have a heated shop with all the air tools so I will not be fighting the weather.
I am also going to replace the oil pump gasket, drive belt and timing belt while I have everything appart.
Secondly, is it easier to remove the exhaust and intake assemblies and just remove the head from the car, or should I remove head with the intake and exhaust assemblies attached and then remove once head is out of car? Seems like the intake bolts will be a bear to get to while in the car.
Is there any surprises that I should expect? I have the rebuild head from Cylinder Heads International sitting on the workbench, a head gasket kit that includes everything needed including new bolts.
Will I have to adjust the valves once the head is installed? I am thinking that they should be preset from the manufacture but I am not sure.
